I removed 2 recaro sports seats from the 72T today.
Had to use the easy out on a couple of the screws holding the runners in place
Having done this 3 times before I knew pretty much what to expect thay are not that well designed and 40 years takes it toll plus there was a bit of metal sticking into the back of the drivers seat so I knew all was not well.
Same old problems as usual broken and very bent frame and broken/rusted captive nuts where recliner mechanism attaches.
Time to get to the welders and get them back in shape
I have dismanted the tilt mechanism and the recliner mechanism and they are off to the paint shop and all the plated runners and levers are off to the plater.
The hardest part of re assembly is getting the main sprink back on the recliner mechanism. Its a real bitch.
