Clutch pedal spring
    Clutch pedal spring
    This is the spring that goes on the clutch pedal shaft on the pedal board, Its NLA everywhere. Does anyone have one kicking around.
    Kane Kennedy
    Typ 901 Register #204
    71 911E Metallic Green
    Might of solved the problem, thats the L/H one. Appears to be the same, plenty of them around.
    Kane Kennedy
      Slight difference when you see them next to each other, but should be able to bend it, to make it rigjt.
      Kane Kennedy
        ....Kane, sometimes I also talk to myself.
        Peter Williams #049
        Secretary TYP901
          Kane it will be spring steel, won't take being bent very well!
            yeah you got me
            Kane Kennedy
              yep your right, was thinking that myself too, hopefully it will work. Otherwise I'm back to square one
              Kane Kennedy
                So too close the loop and for anyone needing this item, I found the spring at Sportwagen Eckert, German based. About $125 to the door, Expensive! But when you need it, what other option do you have.
                Kane Kennedy
                  $125 bucks for a spring!!! Jesus Christ.
                    Ouch
                    '71 911 T 2.7
                    TYP 901 Register #16
                    Early 911S Register #2460
                    Looking for engine # 6112862
                      Bloody hell, that hurts
