Hi,
new poster here. I recently acquired a 1971 911T. I have just finished a full strip down in prep for a complete restore up to S/T spec. I have found some crash damage in the rear which wasn't found before the car was imported. there is a depression in the RH inner guard in the shape of a wheel rim just opposite the shock tower cross member into the chassis rail. This impact has caused everything rear of the shock tower cross member to move slightly to the right, there is a kink on the inner LH chassis rail where the cross member has depressed into it and a seem has been popped on the RH side just next to the cross member. The damage sounds significant but has only moved about 15-20mm but it is enough to compromise the structure and alignment at the back of the car, I do believe its fixable.
As a result of this I am now chasing a rear clip from the shock tower cross member rearwards. i only need the two chassis rails and the cross member.
Is there anybody out there that could help me, even if someone could provide the chassis rails in sections for me to cut up and I can get the cross member else where this would be greatly appreciated.
Dylan
Dylan
