I'm just back from Oran Park where I did the Peter Findlay 2 day drive school, including the lecture & test/s for a CAMS PC &/or rally license, which was a blast, heaps of driving & learning, & no damage to anything but brake pads & tyres.
Which leads to my question/problem. During the high speed braking excercises (100-140km/hr to stop) on a wet/damp track I was constantly getting a lock up on the front left (passenger) side, no pulling either way, ended up with a couple of small flat spots, (so probably not a rotor issue), still had control, drivers side was fine/normal, I had no issues on a dry track on the 1st day. I'm thinking that it may be a sticking caliper? or a weight/balance issue? Any thoughts will be appreciated.
Jappy
Jappy
