I have for some time viewed with skepticism the likely benefit of using the clay block method to remove fine grit etc from car paint . I have seen them advertised and couldn't resist last week after feeling how bad the paint on my Ford Fairmont felt.
Well I am here to tell you it bloody works like you wouldn't believe.
With very little effort, you spray on a supplied solution and then rub the clay block over the surface, it returned my paintwork to a smooth glass like finish which then looked awesome after applying some polish, in fact it has never looked this good.
Then tried my daughters Pulsar, same result awesome! It even got rid of some over spray.
Then did wife#4 car and same again, awesome.
Highly, highly recommend you put it on your Santa list boys.
I bought Meguires but there are others around also. I have done 3 complete cars for a cost of $35 and there is still plenty of solution left.
