Well, not really...
I currently run a fresh 2.7RS spec engine (7R case) with new P&C/cams/heads etc.. that I built for my ST interpretation. Unfortunately I screwed up sealing the case at the #8 (nose) bearing and I have an ongoing leak that gives me the sh!ts.
Sitting under my workbench is the matching number 2.0T engine for my car (3R case). Without a whole lot of work; I could rebuild the correct engine into a 2.5 ST spec engine with the gear off the RS. RS p&c mated to the 66mm crank works out roughly at 2.5 litres. I'd then have the 7R case with fresh machining and time-certing to sell off.
What is the general consensus amongst you my learned friends? Build myself a 2.5 screamer to number match the period correct chassis (Karmann T shell, sunroof delete) ST interpretation? or reseal up the 2.7RS spec donk?
If any of you have built such an engine; what are the pitfalls to watch out for? Would it fit into current CAMS requirements?
