Do you know the best way to jack up the rear of an early 911
Purchased the jack pad and put it into the slot to use as a jacking point. Found that it has a tendency to slip which raises my blood pressure a little. The entire side of the car comes up with the rear wheel still touching the ground. Managed to get the front wheel off but not the back.
Are there any easier jacking points which are easy to access? Tried the protruding point forward of the rear wheel but the jack doesn't extend that far. Was also thinking this was a better point for a jack stand than a trolley jack.
