Dropped off US 911L at PCM for first going over.
Good news was told it was 2nd one built and maybe a show car in US - they are researching car.
Alloy engine cases.
Bad news was the S upgrades were not done properly.
No IDS Webers which I knew. But S spec heads ok.
Cam was more aggressive than S cam which will be brought back to S spec.
So full tear down to ensure bottom end can cope with new mahle S pistons and barrels.
Galleries to be checked that oil mods are right for Carrera tensioners.
Distributor to be rebuilt. New flywheel too. Nitrided rocker shafts also needed.
Peter is a great person to deal with on the car.
Alloy engine cases.
