I've read that the 6X15 steel wheel is heavier than the equivalent flat 6 fuch rim. Has anybody measured the weight differential? My car was delivered with Steel wheels, but rides on the Fuchs - i'll be looking for a set of Steel's.
Weight Difference; Steel vs flat 6?
On the weights the "deep 6" wheels are 5.7 kgs, I dont have a weight for flat 6's but the later center prong 6x15's are 5.4 kgs (i suspect the flat 6's are between the two in weight. but closer to the center prongs)
the only weight i have for steel wheels is for the 4.5 x 15's that is 7.5kgs and 8.7kgs for the 5.5'sHugh Hodges
This has some info http://www.early911sregistry.org/for...h-steel-wheels
10 lbs difference per wheel or 40 lbs extra unsprung weight for the steelies over Fuchs (P3 above) Also on the same page is a link to an ally copy of steel wheelsLast edited by Merv; 06-06-18, 02:22 PM.
Thanks guys, are you referring to the 904 Steel / Alloy re-production factory rims? If so, I have seen them for sale, and at 2250 GBP per rim they are right off the charts in terms of cost. Is there another manufacturer with a more realistic proposition, or are you referring to another (alloy) wheel entirely?
You can buy repro or refurb wheels wheels here
http://www.sierramadrecollection.com...ed-p19697.html
http://www.sierramadrecollection.com...15-p22237.html
I recently bought a set of 5 wheels for 1150 USD plus another 800 USD for re chroming plus shipping of another $600USD I expect given the weights and size.
Yes that's the place I was referring too as well Merv. I mailed for a price but haven't heard back.Originally posted by Merv View PostThese guys say they make alloy reproductions for early 911's https://www.alloyreplicas.com
Okay so I asked about 15x6's and also 15 x 7's in the 7R offset - Chris wrote back last night and said this;
Ben, Our model C's polished start at $3300 for a set of 15x6's. The 5.5" wide is a custom width and is another $200 per wheel to make those. We also have 7 and 8" wide and we adjust our offsets in .125" increments.
So seems like 5.5's would be $4,100 a set.
I've asked to clarify that the 7's and 8's are $3,300 - sounds like they could do a 7R off set to fit under a swb rear guard.
I've also asked what cost for different finishes ....
