Cleaning up and replacing plastic bushes with bronze. Pic is set up without any bushes or springs etc except for the 2 (plastic) bushes the accelerator rod sits in . Clutch spring (shown) is busted so I'll need to replace that and everything will be tidied up and painted/powder coated.
Question: when set up I can move the accelerator rod from left to right about 8-10mm as per pics. Is this normal or shd there be another bush or something that eliminates/minimises that lateral movement?
Mitchell
Mitchell
