As many of you know I am in the process of buying this black 911T in Adelaide.
I was reviewing some info the seller had given me and came across the engine number - 6144698. Hang on!!
The car was described as having a 2.2, recently built, ? original motor.
This number correlated with a K-Jetronic 2.7.
Previously had checked up on the chassis number, but should have checked the engine number from the get go - silly mistake.
Anyway to cut a long story short, I ended up going around and looking at it again and took some photos. The reason why I believe that it was recorded incorrectly is because there is some oxidation/corrosion here and the original '1' was not very distinct. At some stage someone had tried to scratch the '1' to make it more legible.
I have attached some photos so you guys can give your opinions if you think this is legit vs dodgy. Also based on these numbers can you tell if it is the original engine, or does one have to contact porsche?
The actual numbers are (which I believe do correlate with '71 T):
Engine serial number - 6114698
Engine type number - 911/07
Chassis number - 9111120589
