Any recommendations on a reputable shop for dizzy testing and rebuild in OZ?
Distributor rebuilds
sort of ditto for me.
I need to replace the original marelli that is in my car at the moment, with a bosch unit. from talking to Phil Hearn, a used bosch T distributor can be rebuilt and mapped to suit my 2.8... Phil never mentioned where to get the rebuild done - only to come up with the unit and he will sort it out.
so, Duncan - maybe contact Phil?
also, if anyone has a 911T bosch dizzy lying around...?Richard Griffiths
Duncan, ditto on Performance Ignitions (Bayswater)... I think they used to be known as Scorcher Ignitions. They rebuilt and re-graphed mine several years ago, and I've had no issues at all.John Forcier
hey duncan
care to disclose what the cost of the rebuild was? I need to get off my backside and find a base distributor to get rebuilt and recurved to suit my engine...
not sure how much the used unit will cost, but would be good to know how much to get it fixed and working and in the car is.
richRichard Griffiths
Are you guys aware that you can take a basic 2.7 "late" distributor and machine the whole thing down to early specs and have it curved to you engine's spec?
My 2.0 had a Marelli originally and the cost to replace with the correct Bosch was hideous! John Walker (well known Seattle wrench) stepped me through it over the email $250 for the base s/h dizzy (Swan Porsche), $50 machining, $200 rebuild and recurve (to T spec) at Performance Ignitions... $500 was substantially cheaper than the correct Bosch!
I put a thread on Pelican some years ago - I can revisit the details if anyone wants?Last edited by Fishcop; 04-08-08, 05:10 PM.John Forcier
Here's the original 2002 write up... clearly my dollar memory is useless
Hopefully another side by side photo will up load and you can see what gets done. Basically the later Bosch is turned on a lathe to match the profile of the Marelli. For the earlier engine case, the adjustment lug/casting is machined off and a groove is added to use the Marelli clamp. The O ring groove will end up in a slightly different position, but it doesn't matter. Performance Ignitions remove the vacuum retard and replace it with a neat blanking plate as part of the rebuild cost.
Does that make sense? I also added a Crane XR700 with optical ignition to top it all off.Attached FilesJohn Forcier
Thanks John!!I really should be trying to get some work done and then going home to eat dinner with claire... but dizzy rebuilds are a welcome distraction from trying to work out FY09 plans in this economy!
so, assuming no inflation, and keeping a normal rotor/coil set-up, i could be done for $350-ish?? so maybe $400 these days?
is the new dizzy set up 'plug and play'? or are their timing worries to consider? don't want to be getting ignition at the wrong time!!Richard Griffiths
