1973 911 E 2.4 points
    Hello Everyone,
    In my car the Bosch distributor is a 023 116 9009. (This is the Bosch part number)
    1. Does anyone know the Porsche part number for the above?
    2. Alternatively, does anyone know the correct part number for the points, either Bosch or Porsche, for the above distributor?
    I have the Porsche part numbers for the points as either 901 602 960 04 or 911 602 936 00.
    If I can get the Porsche part number for the distributor, then I can easily cross reference the two.
    Thanks for any information.
    CJ
    not sure if this helps you, from copy of the 73 parts catalogue I have
    '71 911 T 2.7
    TYP 901 Register #16
    Early 911S Register #2460
    Looking for engine # 6112862
      and bosch distributor - porsche part numbers
      Screen Shot 2023-08-12 at 4.13.37 pm.png Screen Shot 2023-08-12 at 4.13.03 pm.png
      '71 911 T 2.7
        Marcus thanks for the info however what I need is the Porsche part number for the distributor. I have identified the Bosch number, but that doesn't assist in selecting the points.
        CJ
          There are a set for sale on early S NOS Carl
            Thanks Clyde, however I still don't know which ones I need. I'm going to buy both, and see which set fits.
              CJ
              As far as I understand it, they are the Porsche part numbers for a ' 73 E in the 2nd screen grab ; 911 602 027 03 (E with a vacuum advance) / or 901 602 027 00 E without a vacuum advance) ...
              '71 911 T 2.7
                Yes, correct. However the number on the distributor is the Bosch number. There are two types, I do not know which type I have. There are two types with vacuum advance.
                  ah ok - you need the translation ..
                  '71 911 T 2.7
