(A) well done Porsche
    Hi all,
    back from lunch with a couple of buddy's (boxster drivers) giving me an awful time about MFI cars and spontaneous combustion and the 1972 911 that recently caught fire up here
    as an ex Melburnian i cant bring myself to read the local rag so completely missed this
    http://www.theherald.com.au/news/loc...t/1435173.aspx
    Craig
    12/1969 E based Vintage Racer
    1972 2.4E Targa project
    1973 911 2.4E for the road
    Ouch! I prefer mine rare.
      Lucky it happened right outside the fire brigade
      Marcus
      TYP901 Member #81
      1972 911E
        Raises the question of fuel hoses replacement. Is this a do it yourself prospect (i'm guessing yes) and can a good quality hose from an auto shop be used?
        Could be cheap insurance.
          Depends if its an MFI car as I believe there are higher pressures involved with these systems.
          Phil Hearn gave me some special fuel hose he uses so will try to find out what it is.
          sigpicPhil Lack
          TYP901 Register Inc. # 002 (Founding President)
          Early 911-S Registry # 690
          R-Gruppe # 367
          '72 911E 2.4 Coupe (SOLD)
          '15 MB CLA 250 Sport Shooting Brake - daily
          2012 BMW 1M Coupe 6-spd (for sale)
          1974 FIAT 124 Sport coupe
            Higher pressure hose is widely available as all modern cars are injected and typically run around 30psi+. I think MFI systems run around 28psi and carby systems will only run at 3-4psi.
            Jeff Eelkema
            TYP 901 #132
            S-Reg #1431
            69E (project)
            various bevel Ducatis
            60s Vespa
              does that mean that carbs are less likely to cause a fire like this?!?
              Richard Griffiths
              1970 911T 2.8
                rich,
                probably not. the pressure may be lower but the voume of fuel supplied is about the same. if you split a line you're in trouble.
                i've been in this situation - for another reason - and its pretty frightening.
                my former 1988 3.2 caught fire in bondi. similar story - started to run rough (it had been raining and it felt like a wet plug lead), stall, big backfire, looked back and it was well alight. luckily managed to put it out fairly quickly (despite reaching down and finding an EMPTY fire extinguisher bracket...).
                the culprit turned out to be one faulty fuel injector which had failed open and filled the cat converter with fuel.
                  Carbs/fuel hoses can still leak and any fuel leak can cause a fire!
                  Jeff Eelkema
                  TYP 901 #132
                  S-Reg #1431
                  69E (project)
                  60s Vespa
                    Yep I regularly check mine. Especially after smelling fuel with the engine running and lifting the engine lid to find a nice steady stream of fuel dripping down the side of the engine on to the SSI's.
                    Just a loose hose clamp.....
                      I've had issues with carbies too. Usually the seal at the banjo fittings (the red fibre washers). I've been meaning to replace them with the PMO 'fuel bars'.
                      John Forcier
