All,
Symptoms
The 70T started to lose idle then stall after 20 minutes or so of driving. The first time it stalled was after approximnately an hour in traffic in the 35 degree heat in Sydney the other weekend.
You could restart the car after a 30 minute 'cool down' time then drive for 10 to 20 minutes and it would basically lose idle and power.
Diagnostic so far
My mechanic has replaced points, checked the fuel flow and pump.
CDI is still making the whine sound on ignition.
The coil is realtively new, last 3 years (completed only 6000 miles since)
From the little piece of resaerch I have done on the Pelican site it could suggest the CDI may have come to its life end, although Warren's posts seem to indicate there are a few more steps in a cleaning and connector type check prior to completely writing it off.
Opinions please?
A new CDI may be required, what are the thoughts of the board? I'm not too concerned about having and origianl Bosch unit, and I have looked at the MSD 6AL and this looks reasonable.
The MSD change looks to be a straightforward 'bolt in', however I haven't completed all the research.
Are there any other possible causes???.. (I have spoken to Lisa and Ryan for some general advice)
Does anyone have a spare CDI that they are willing to sell / part with.
Regards and thanks
Shane
Symptoms
Diagnostic so far
Opinions please?
Regards and thanks
Shane
