installing battery tie down straps
    Hi All,
    Purschased some battery tie down straps today, already have the 2 screw in bits connected, can someone please post pics of how the top 2 straps assemble in, haven't attempted install yet, but don't see how they work,
    There is a clip on the upper inside part of the battery box that the upper battery tie down snaps in to.
    Then wiggle the battery almost into position, attach the two negative and positive and then push battery as far back in to the batteryu box as possible, attach top strap to bottom strap and push down. If its loose adjust tension by turning the bottom strap futher into its threaded piece and vice versa.
    Shouldn't need photos to do all that Chris the hard part is making sure you have the right size battery which allows it to fit properly in to the battery box!!!!
      Thanks Clyde, all done
