You must become a member of the Australian Typ 901 Register in order to be post at this website.
Once you become a member an invitation to register at this website will be emailed to you.
Membership information can be found by clicking here.
Yes Tony, the oil sender units themselves (located in the oil tanks) can become faulty. I believe replacement units are available from Porsche. Fitting them can be a pain because you need to remove the oil tank. Its a good opportunity to give your oil tank a really good clean out.
the connection to the sensor on the engine can often come loose/break contact etc. causing the gauge to show full. i'd check that as a start - maybe crimp on a new connector.
from memory its at the very rear of the engine - just to the right of the fan.
there are also the wire connectors to the sender unit located under the right rear guard which could be the problem.
Ryan, i think that wire you are referring to is for the oil pressure sensor ??
