Had my car in the shop last week to have the brake upgrade done and install my the sport shocks. The car is sensational to drive... the upgraded suspension and stopping power is a great match for the 3.0 installed by the PO (Shane, let me know if you are ever in Adelaide and want a blast in the old girl).
There is however an unusual problem with the brakes and any suggestions would be appreciated. For background the upgrade was to second hand (low mileage) boxster calipers, new carrera rotors, new brake lines, left the original master cylinder. Hawk racing brake pads and racing brake fluid.
After a short drive yesterday the car started to pull left under braking. As it would happen the car was back at Poole's this morning on the hoist for another reason so while it was elevated he took a look at the brakes. Interestingly while applying light brake pressure it was the right that seemed to provide more resistance when turning the wheel, though bugger all in it. Took a look at the rotors and pads which seemed fairly normal, perhaps slightly inconsistent wear patern on the lefts and swapped pads left to right 'just in case'.
Because the torsion bars are tired and showed signs of sagging I asked Mark quickly checked the corner weights - perfect. Probably not necessary but wanted to eliminate this.
So back on the road for another test drive and braking was flawless and remained so for the next 5 kms, then quite abruptly started pulling to the left again.
This was not the case on my trip home from the office after the car sat for a few hours - no problem.
Now the Mark assures me the brakes were very thoroughly flushed to clear all the old fluid, so he feels that is an unlikely cause. Next planned step is to have the caliper pistonsblooked at / cleaned as it seems they may be sticking. Rebuilding a logical step after that. They are second hand and appeared to be in good condition but not sure what else to try.
Any suggestions/thoughts?
