Those who have followed this production will know that considerable experstise from Walt Disney studios (Thanks Chuck) and Mercedes Benz (Thanks Thorsten) have had a hand in determining the final product.
I originally had two casts made and we are using the best of both
We will be retaining the outer burgundy ring in the second picture and transferring it to the badge without the white paint infills, first picture.
The badge pictures have some reflection and the image is much sharper than it appears yet retain the "old style" look in keeping with the age of our cars.
We are putting in two pre drilled holes so mounting or sticking can be done depending on desires. We will not be supplying a mounting kit.
I have ordered 40 pieces should be available to sell in 3 weeks. First in first seved
Price will be $45.00 inculding postage to anywhere in mainland Australia. Its a little more expensive than some badges which is caused by the small numbers ordered.
Put your hands up now and I will reserve pieces for you.
If we run out of the initial order it will be another 3 weeks before more are available.
