Hi All
Just a couple of other questions...
1) As a temporary solution to my steering wheel, thought I would try (roughly) re-stitching the leather. Any ideas on where to get the black thread?
2) What should the oil level meter in the car do whilst idling/running? Idle shows oil (5-7L), when it's running the oil level drops to basically nothing. Oil pressume is within what the owners manual suggests. Temperature is what I would think is the cool side of normal... but it has been cold everytime I have run the car.
3) The indicator return switch is not always holding, presume this is going to mean replacement rather than repair? Also think they are one of those hard to find bits? Have all the bits off the car, so will go and try and understand how it works.
4) What should fuel consumption be for a 2.8? I think it sucked down about 9 litres in 35 miles or so... none of it would have been particularly efficient driving, and using a very small sample size. Also, the stutter could always have been some cr&* going through the carbs, I stopped pretty quick (like 30 seconds) and filled her up from a can... no more stutter.
5) The bolt that holds my starter motor on is borderline. It is too long, and is getting rounded. I really don't want it to get fully rounded and have to drop the engine out! It is bad enough having to hug the gearbox to get the damn thing in/out (someone at porsche has some explaining to do!). What is the bolt and how hard are they to find?
6) The windscreen washer pump seems to be running, but no water comes out (have tried the pin in the jets trick). Any suggestions?
Sorry, more than a couple of questions there, but any ideas would be great!
Rich
Rich
