Looking for some advice.
My car has aftermarket sway bars that do an excellent job. This does however come at a price. The car is a daily driver and while I do not find the ride too harsh at all the setup is noisy. I disconnected drop links today and the noise problem is gone, so sway bars are definitely the culprit.
Considering replacing the drop link rod ends with some with a quieter bushing (current are metal on metal). Assuming the sizes I require are commonly available then guessing I have a couple of options. Nylon which will wear more quickly (and possibly not perform as well?) or a higher end product (with smaller tolerances and therefore I assume less noise).
Any advice on what solution to consider and a good supplier.
