Righto,
I'm currently running two normal sized batteries in the car which means I can't get the spare to sit down in the wheel well as is should.
I have a couple of questions...
1. As the drivers side battery appears to be the one stopping the wheel sitting right down, is it OK to run one 'normal' sized battery and one small battery? I'm thinking of buying one of the factory type battery tie down straps to replace the aluminium one that has been rigged up to suit the big battery.
2. What type of batteries are you guys running and are they rudely expensive? Also where are you getting them from...? Any model nos. etc would be a help
