I took the 71T for a run yesterday and was just thinking how reliable it's been. However as I was pulling into my garage it died. At least it chose the best moment and I could push it in. I suspected ignition as it cut cleanly and did not even give a splutter when I tried to crank it.
The transparent fuel filter was full and I could hear the pump running. I can also hear the high pitched zing from the CDI box. I checked for spark with a timing light and got none. Fuses are ok. The car doesn't have an immobiliser. With the cap off the rotor is turning. Given the high voltage I don't quite know how to test things.
The coil is new and has a warning sticker about putting a tester on it.
Can I assume that the CDI box is working because it's making its usual noise?
I do have a Pertronix electronic ignition module in the Bosch distributor which is also quite new. Could this be tested by putting a light in series with the return wire that goes to the CDI box? Would I expect to get the light on and then flashing off for each ignition signal as I crank it? If that's my correct understanding of how the old points would have signalled the CDI box.
Also when cranking the engine with the ignition on but distributor cap off should I be making a temporary path for the coil discharge to ground to prevent damage to the coil or CDI?
I have the old Marelli distributor which I could put in but I would ideally like to narrow it down a bit before doing that.
