I Have installed one window so far and am very happy with the fit. I still need the correct lower trim piece from SierraMadre to arrive to complete it.
I currently have M5 Bolts holding the frame into the B pillar but am unsure of what the "correct" head should be on the bolt. There is little room to counter sink anything there.... so is it normal to have the head of the bolts or screw protruding through the lining when the lining is replaced?
Pictures could be helpful. Thanks in advance
