Repainting dash
    Repainting dash
    Hi all,
    The metal area around the 5 instruments is looking a bit faded and tired. (not sure why it wasn't repainted as part of the restoration).
    As I have the 5 instruments out for cleaning and changing bulbs to LED, I was wondering whether I should attempt to repaint this small area. I think the colour is satin black.
    However, painting this small area using a rattle can, even if I tape off surrounding areas and somehow shield the rest of the interior has the risk of disaster - black paint filling the cabin with all new interior.
    Another option could be a super small highest quality hand roller but what would the finish look like?
    Has anyone attempted this WITH the rest of the interior remaining in the car?
    Or do I just except it.
    Any thoughts very welcome.
    Mark Evans
    1966 912 5 gauge
    1968 Mercedes Benz 280SL
    Spray it with a can. Wurth and Rustoleum make a satin black that looks great. Just cover everything and you will be fine. Look at Pelican for people who have posted doing the ame.
      Should be no problem with a quality rattle can, as they have better nozzles as well as better paint (UPol,Wurth) or similar.
      Mask as you described, and have good ventilation, disposable drop sheets are only a couple of dollars, to cover seats etc.
        Tim beat me to it.
          Many of the old time car paint guys used brushes with slower drying paint. High quality brush with a satin black enamel if you are worried?
            Or sit the tin of paint in a bath of hot water. Brush the warm paint on. Awesome finish.
              But I would use a rattle can as Tim and Chris have already mentioned.
                Many thanks for your opinions. I will forge ahead and take a before and after photo to post.
                Mark Evans
                1966 912 5 gauge
                  Hi Mark
                  Is the switch to LED for the gauges simple?
                  Adam
                    Originally posted by AdamGill View Post
                    Hi Mark
                    Adam
                    a ten year old could do it Adam,
                    GRC930, Graham
                      Hi Adam. Agree.
                      Easy to access instruments (compared to my MB that was a 2 day job!) and very easy to actually replace but, the real trick is getting the type of LED that:[*]substitutes the BA 7 2W, [*]fits the globe holders OK, [*]provides sufficiently wide beam rather than too narrow[*]gives off a white colour that you find OK (I prefer a "softer" white)[/LIST]
                      Mark Evans
                      1966 912 5 gauge
                        Thanks Mark
                        What LED's did you buy?
                        Adam
                          Hi Adam.
                          For the dash I have ordered some "vintage white" from: www.carmagic.us
                          Have not received them yet but will let you know.
                          For my rear tail lights (and stop) & reverse and front parkers I have used some from: www.brightlightautoparts.com
                          Bright light autoparts (in Bayswater) did not have the BA7's with 180/270/360 degree not in a vintage white.
                          For my MB is used some from superbrightled in the US that were a softer white.
                          Mark Evans
                          1966 912 5 gauge
                            Thanks Mark
                              Hi Mark
                              Any photos of the finished dash?
                              When I got mine it had vinyl behind the gauges, I didn't realize that it was painted.
                              Ash
                              1971 911E
                              1993 964 30 Jahre 'Jubilee' Edition Looking for engine 6218087
