I've recently started driving my car after a 3 month break while I renewed the entire front suspension. Since getting it back on the road it's been suffering from some intermittent engine problems that I'm struggling to fix. I also pulled the tank out at the time of suspension and resealed inside of it. I can't see how it's related to the issue, but including this for context.
Here's what happens
The car starts, idles and drives completely perfectly until it gets up to temperature and I give the accelerator a little blast past 3500rpm with quick acceleration. Standard slow acceleration is fine. Shortly after that it dies like it's intermittently losing power. The engine dies and I pull off the road. It will restart and if I can manage to keep the revs above 2500 I can keep the engine running, but it splutters, coughs (no backfire) and generally wants to stop. When it happens I've checked lose ignition wiring etc, but cannot find anything. It kind of seems like a dirty fuel crossed with ignition problem. Without doing anything it eventually fixes itself and away I drive until next time.
Today I replaced rotor and distributor cap and it happened again after I took it for a drive. It has MSD, new coil and leads about 18 months ago and it's never given me a minutes trouble, all are relatively new.
The strange thing is that if I don't give it a little blast it drives fine. I also can't reproduce the problem with it at temperature and revving it while stopped.
I thought distributor advance might be sticking but can't think of a way to check timing on my own with car running. A basic check of distributor with cap off and twisting the shaft shows normal spring advance action.
It always comes right after about 5 minutes of 2500-3000 revs while stationary.
Thoughts?
Here's what happens
Thoughts?
