My 1967 will most likely need new rotors front and rear as well as new pads and lines in the not too distant future so I've been thinking that it may be a good opportunity to improve the setup.
After some light reading, I stumbled across someone who used Brembo calipers from a ‘80s Alfa Romeo GTV-6/Milano. Apparently they retain the 3 inch bolt spacing like the 912 but with 48mm pistons like the aluminum early 911S caliper. They’ll also mate up to SC rotors and the pad retaining pins are sold by PMB in Utah. A quick Google search returned a used set good for refurb on eBay which sold earlier this year:
Any other suggestions? Anyone running this set up - if so, feedback?
