I'm back with more questions for the gurus
So it's pretty obvious I have no idea, here's my issue.
I have boxter brakes and 3.2 rotors, I think.
When test fitting the rim it rubs on the bottom of the strut.
I do realise that when the front end is back in the car the wishbone will sit more horizontal than what it currently is however I can't see that it will increase the clearance between the inside of the rim and the bottom of the strut by more than a couple of mm unless i'm looking at it all wrong.
So question one is what should the approx. clearance be (15"wheels)?
Would the struts have been changed to accommodate these brakes?
I don't know how to ID them although the caliper mounting holes are 90mm apart if that helps.
Thanks again.
Thanks again.
