Hi all.
I need some guidance as to the position of the bonnet relative to the body.
Mine may not be correct.
I know that normal gaps are around 3mm. However, should there be any difference in height between the bonnet and the body, is there a "normal" height difference or should the bonnet align horizontially with the body?
The right back of my bonnet is 2.5/3.00mm ABOVE the height of the body. The gap ok approx at 3mm.
Interestingly, the left side of the bonnet is only 1mm above, so at any rate there is a difference side to side.
Can anyone explain if there is a procedure to adjust the height of the bonnet.
Currently there are no shims/washers between the bonnet and the hinge that is bolted to the inner fender with 3 bolts.
