Magnesium not aluminium.
Opinions on value of 901 box in full working order?
Originally posted by Bremith View Post(On my limited understanding) very early ones were al. The one I have is 911/02 I think.
Had a quick look and couldn't find a 911/02, 901/02 comes up as 67/68's gbox. I have a 902/01 in my 912. 911/01 were available 70/71.Aus del 68 911S
It's value depends on whether you need it or not.
The 911 was transition box between the aluminium 901 and the later 915 - though internally identical to a 901 except for the differential. I think it's correct for late 69, 70 and 71. It is the 'awkward' clutch arrangement with the push clutch operated by the sheath and not the cable.
Down side of mag is that the bearings can shag out in the softer metal - they end up spinning in the bore. There are repairs for this of course, but it's all dollars.
Internals ware where the value is... If it has an LSD it's the larger and more useful version. What are the ratios? Key here is the mainshaft... second is incorporated/welded, so the ratios necessarily peel off what fthe mainshaft is set at. Most will be 'F' second gear. Early boxes were A F M S X and later boxes have taller gearing as standard as engine got torquier. Gear sets are worth $200-300 each.
Value? Dunno. They pop up semi regularly in the States from $500-3000 but it all depends on condition inside. Gears, spiders, sliders, dog-rings and synchros are really expensive now. And gears 1 and 2 are notoriously short lived in an abused box - and of course a damaged 2nd means a new mainshaft.
I understand there can be complications with using this box arrangement in the wrong year - the drive flanges are 6 bolt but the larger diameter and there can be issues with spline counts when using other flanges (especially if LSD equipped).John Forcier
Pretty sure the 911 box posted by Chris last fortnight is similar to what you have - It sold for $1255
It was ugly, had no clutch or TO arm.
