Hi all. I think I am needing a new / secondhand headlight switch. Symptoms are all lights work except the main driving lights (front) both sides. Hi Beams still work but only when you pull back on the stork and hold...they do not work when pushed forward. Rear lights indicators etc all working. The unit seams to have lost the hold (click) between parking lights and driving lights. Globes are ok. I was hoping the switch may be servicabe but looks like a closed unit. I pulled the switch out with no obvious signs of the problem. Seeing if anyone has a working switch they may like to sell or any feedback on my symptoms. Part number is 911.613.029.01 Cheers
Wanted headlight switch/pull replacement
Originally posted by CS911E View PostHi Mick,
I have this in my spares, is this the one you are looking for?
CraigLast edited by Mick Case; 18-02-24, 05:33 AM.Mick
Originally posted by Mick Case View Post
Hi Craig. Thanks for responding to my post. Unfortunately your one looks like one from a later model. The earlier switch that I am chasing are quite different. Thanks again for your reply. Kind regards MickCraig Sedgman
914/6 GT Clone Project
996 C2.1
Hi Mick
PM sent yesterday.
Cheers TomTom Laube
Instagram - #first_corner_fever
Porsche - '73 LHD 911T, '72 RHD 911T, '79 All Rounder SC
VW - '60 Type1 Factory Sunroof, '64 Kombi
Originally posted by Mick Case View PostHi all. I think I am needing a new / secondhand headlight switch. Symptoms are all lights work except the main driving lights (front) both sides. Hi Beams still work but only when you pull back on the stork and hold...they do not work when pushed forward. Rear lights indicators etc all working. The unit seams to have lost the hold (click) between parking lights and driving lights. Globes are ok. I was hoping the switch may be servicabe but looks like a closed unit. I pulled the switch out with no obvious signs of the problem. Seeing if anyone has a working switch they may like to sell or any feedback on my symptoms. Part number is 911.613.029.01 CheersClyde Boyer
Thanks Clyde. I have sourced a second hand switch, and I'll see how that goes when I can fit it to the car next weekend. Was it just your headlights that were not working or were there other symptoms or lights not coming on? From looking at the back of the switch, there is only one contact for each side of the headlights and parkers . That is the right head light and parkers (front and rear) have only one contact and the same for the Left . I'm guessing the 2 stage switch dictates the difference between the parkers and headlights as there is no seperate circuit? I have looked for a headlight relay but could only find my high beams and indicator Relays.Mick
Mine was the relay under the dash everything worked fine except main beams can't confirm if I had to hold high beam as I just flashed them to see if they worked never put them on permanently that I can remember.
Auto Elec attended to mine out of my pay grade.Clyde Boyer
- Likes 1
Well it has been an interesting process but the headlights are working again. I was able to source a reasonably priced 2nd hand switch but Unfortunately it didn't work correctly. I was happy to keep it as I could swap out a switch and keep all the wires connected to the other unit keeping all my wires in place. The second hand unit, even though it wasn't working properly, did turn the headlights on but not in the right position . The dash lights wouldn't turn off and there were a number of lights that just didn't work.
With nothing to loose I thought I'd pull the second hand one apart and although it didn't appear to have been opened before the centre pull section was clearly not put in the correct way..( Accounting for its erratic behaviour) With that discovery I thought it would be an easy fix to realign the contacts and all would be good. After it was all back together I put it in the car and everything worked but not the headlights. Now with the original unit out I thought I couldn't be any worse off so I pulled apart that unit. I discovered the base plate which holds a spring and a small ball bearing that creates the 2 notch pull in the switch had come apart. Once again I thought easy fix. Once all back together I swapped it into the car. All the lights worked but not the headlights.
I didn't want to be defeated so I swapped / checked / opened and clean both the switches but still each time with no headlights.
As yet I had not pulled the centre section or stork apart which holds a number of components which slides within the unit. There was nothing visibly wrong but I thought I'd look anyway. I discovered that there is a contact that runs in-between the components that had failed or shorted out. I was able to fix this with some MacGyvering and some brass picture components . After placing back in the car.............everything works including the headlights !! I decided to look at the other switch and it suffered from the same problem.
Fixed that one up and now I have a spare.
In conclusion I learnt a lot and realised that they are a very serviceable component.Mick
- Likes 2
