Headlight packages and items
    SOLD to Tim
    Due to a change in direction about how I am setting up the headlights, and lighting in general in my car, I am offering up a number of headlight related items that are now surplus to my requirements.
    the major items (full details below) are:
    two RHD Marchal Amplilux 7 inch headlights for $600 for the pair (plus postage)
    two SWB Hella SB19 20 21 headlight buckets including the glass, new rims seals etc for $500 for the pair (plus postage)
    Although I would sell all as a complete headlight set for $1000.(plus postage)
    This headlight setup was used in period for 911 rally cars and for many 911 entrants for the le mans 24 hour race and similar. These, using either the Amplilux units or the carrello Biodes depending on sponsors, were the lighting units to have and can be set up to have 70w low beam and 130 w high beam (which on the Amplilux is effectively a driving light) giving as much lighting power as you would get with the CIBIE hood lights alongside regular headlights. (The Amplilux's were also used on the BDA Escort rally cars of the time)
    The amplilux units (code 612 830 03 for RHD) are used but have excellent lenses etc. The only blemish on them is that all the mounting tabs have been cut back, as can be seen in the first picture (probably to fit some other application - otherwise i would be asking much more for them). This does not prevent them from being mounted properly but it does make it a bit trickier. They have also been wired with a modern connecting plug, the other part of which can be attached to the wiring inside the 911 headlight bucket so that they can be swapped in and out with your normal lights if required. (see photo 3)
    the SWB Hella SB19 20 21 headlight units have been water blasted and painted in a silver/ grey color close to original and have been rebuilt with new (reproduction) chrome trims from auto foreign services (Eric Linden) in the USA, new gaskets etc, and old SB19 20 21 clear headlight lenses.
    One of the headlight lenses has raised scrip on the outside and very light pitting - its code (for those into date coding) is 28-60370-03 and the other one is also an older one but does not have any pitting) but has the scrip on the inside and is coded 032-60370-03. (I understand that the newest reproductions of these do not have any such coding)
    see photos 4 5 and 6 for the buckets
    the rest of the photos show the ampliluxes mounted in the headlight buckets.
    I also have a number of other parts - chrome trims both new and used as well as older (and more sandblasted lenses) that i will list separately
    Hugh Hodges
    1973 E
    Australian TYP 901 Register #005
    Early 911S Register #776
    I also have the following items available for sale
    band new still in packaging reproduction chrome light trim ring (from Eric Linden Autoforeign services in USA) $90 plus postage sold to Michel
    2 used chrome headlight rings with screws both not perfectsold to Michel
    1 with only a very small dint at about 2pm position $60
    the other with a larger dint at 5PM position so cant really see it when on a car (but probably quite fixable) $40
    2 used SB 19 20 21 glass headlight lenses Both with raised script on outside and with various amounts of sandblasting but usable
    1st one code 18-60370-3 $40
    2nd one code 21-60370-03 $45
    (i understand the lower the first number the earlier they are and the second one has the least sandblasting)
    Finally a Kroon wiring harness for a 1973 (and probably earlier) car for fog lights from switch to fuse box etc - cost me 129 euro plus postage sell for $100 plus postage sold to Michel
    Hugh Hodges
    1973 E
      Hugh I'll take dibs on what your offering - I'll call am to discuss
      Cheers Michel
        Ok pending until after I discuss with Michel
        Hugh Hodges
        1973 E
          2nd in line Hugh. Please
            I will take Eric's repo headlight rings if available please Hugh.
            Jap del 75 911 lhd 3.2
              Tim
              Michel says he will pass for the time being on the buckets and marchals but is wanting the other parts
              what was your interest before putting this back to everyone else
              Hugh Hodges
              1973 E
                most things sold now to Tim or Michel
                the 2 lenses still available but i am happy to keep them if not wanted
                Hugh Hodges
                1973 E
                  Thx Hugh.
