What are the thoughts about Pirelli Cinturato CN36 versus Michelin Classic XWX for my 1970 2.2s - 185/70/15
Classic tyres
IMG_1306.JPG Like Merv I have XWX 185's and I don't recall having any of the stone pickup issue of the CN36's as mentioned by Scotty.
Mark Evans
1966 912 5 gauge
1968 Mercedes Benz 280SL
CN36's N4 compound ( Porsche worked with Pirelli on them).
I can confirm they are great - and they do chuck the stones around a little but I imagine all of the original style tread patterns are not as open cut as contemporary tyres.
185. You have period moulds, but modern construction and compounds. Best of both worlds.
JRYou do not have permission to view this gallery.
This gallery has 2 photos.Justin Reed
I'm running the Avon CR6ZZ on my 71S. It's a great tyre, available in Australia in the correct sizes. Despite being described as "a road legal race tyre" I've found it to wear well and be particularly good in rain.Originally posted by hyphen911s View PostWhat are the thoughts about Pirelli Cinturato CN36 versus Michelin Classic XWX for my 1970 2.2s - 185/70/15
If you look at the thickness of the sidewall of the Avon Tyre you can see why it should not be compared to the Michelin or Pirelli tyres.
They are designed to be supple and pliable to create a ride as close to the tyres of the era, whereas the Avon is effectively an R spec tyre and changes the ride characteristics.
It's a softer competition compound, but I'd be surprised if many of us put enough km on our cars to wear out a tyre in 5 years. With our typical "light use" you do have to be disciplined about rotating the tyres regularly or you'll end up with flat spots. I remember someone (Hugh?) had a problem with this.Originally posted by ELSPORTO View PostI bought a set of Avons too ... yet to run them. Bit shocked at the tread wear rating of 80
My bf goodrich t/a's are rated 400 ....Last edited by npvpositive; 30-01-18, 09:07 AM.
The sidewall on the Avon is definitely stiffer. I've never run the Pirelli or Michelin alternatives so I can't comment on the impact on ride quality . . . seems fine to me though.Originally posted by 9er View PostIf you look at the thickness of the sidewall of the Avon Tyre you can see why it should not be compared to the Michelin or Pirelli tyres.
