I have a 2.2 1971 911. I removed 8 bolt round bottom oil drain plate to replace leaking gasket.
I found 30mm spring clip laying on wire mesh and also found alloy suction pipe from oil pump very loose. I could remove by hand.
Motor has been running. Can anyone let me know what holds the suction pipe in pump and is the spring clip part of it?
