looking for a little help.
The oil level gauge was working fine then it just stopped working. Now when I turn the ignition on the gauge shows full it doesn't move from there until the ignition is turned off. Have replaced the sender in the dry sump tank still the same, ran a wire from the gauge to the sender, started the engine the gauge works perfect.
I think it could be a wiring problem.
