My recently finished 1972 911E Sporto is "groaning" in the front end.... have tracked the noise to the bushes in the suspension, I've already pulled them out once and used some special expensive grease from Grant at Autohaus.... was quiet for about 50klms then started to squeak and groan again .... have I installed the wrong sort of bushes ?
Pretty sure they are a nylon/nolathane bush and quite a tight fit, even with grease - am I pushing all the grease out ?
appreciate any advice
Many thanks
Many thanks
