Hi Guys,
I'm in the throws of getting the car back on the road later this week (basic on-road stuff only, still lots to do...) - I'll be running both standard type seatbelts and 6-pt harnesses. I wanted to check what others have done for the harness setup - mainly the sub straps.
Based on a few searches of the Pelican site I'm assuming drilling through the floor approx 20 degrees back and 20 degres each side from the seat base strap hole, with welded in reinforcing plates under the floor?
Pics would be good if you have them!
Cheers, A.
Cheers, A.
