No not shock therapy...yet!
Last winter, I tried the two stage rear demister on my 69s. FAIL.
Quick zap from front left ( not sure whether under dash or beyond) and the light on the demister knob went out after a brief illumination.
This has also caused the blower fan to no longer work after the same incident.
Does anyone have any ideas where to start? Fuses all appear intact - as it happens, wiring diagrams suggest these devices are not fused.
The lighter, which appears on the same circuit is working.
Wiring is reasonably tidy underdash and bonnet ( fuse area a bit messy) and I've had the engine bay rewired.
Any ideas would be of great help! BTW it's 39 degrees today so an odd one to start thinking about!!
