Im rebuilding suspension at present ER bits and have decided to replace the transmission mounts. As the 901 rubber bushes are not readily replaceable and not wanting to buy New $780.00 carrier. I'm assuming there is a DIY fix.
Has anyone swapped out the original rubber bushes and replaced new? If so pressed out?
do the various aftermarket, oem bushes fit properly - types?
Other option would be to modify 915 carrier to take the 901 box allowing ready replacement. Anything special to consider with this option?
Any other options?
Any other options?
