good point Ryan!
Forgot all about that. So long as you don't have narrow guards, we found out the hard way, or at least Marcus did, they are the wrong offset, you need to roll the guards. If you have wider rear guards you can put them on.
Marcus only bought the 6 inch ones though, so I don't know what the offset is on the 8 inch ones. The wheeels are of a high quality, but they will probably require longer wheels studs than you have, and the wheel nuts are a different shampher (spelling) to the Porsche nuts. However they looks awesome! You can get the UK Minilites, which are more expensive, however they have the correct offset and shampher.
There ya go!
There ya go!
