It might be late onset ADHD but I just couldn’t find the patience to perfect the art of fine-tuning the mixture on my Webers. Always good for an easy way out I ended up picking up an Innovate LM2 wide band A/F meter off fleebay. This thing will measure mixture and log it against RPM and could be ideal for finely dialling carbs in.
Plan is to have 6 S/S bungs welded into my SSI’s so I can get the mixture correct off each carb throat. It’ll also be handy with a new little project which has an SU.
