I currently have a Tacho dated 65' and a Mallory Super CD 28600 ignition.
I purchased a Tach Adapt as previous owner apparently researched it.
I can't get the Tacho to work!!!!
Any help would be appreciated
I have 3 outputs from Mallory .
1. +12v
2. Points
3. + Coil
I have 3 wires in back of Tach
1. +12
2. 1 (which is tach wire straight through to the engine)
3. not sure!!!!
I was thinking about upgrading the whole lot as I have read that the tach will not work unless modded.
So do I send Tach away to be modded and upgrade to a MSD setup (or similar) or does someone know a quick fix.
Confusing yes I know.
Jim
1. +12v
2. Points
3. + Coil
1. +12
3. not sure!!!!
Jim
