These are for a fellow member who wants to get the correct allen key screws and nut for his engine grille for a 69. Won't tell you who it is though.
What you need are 6 x M5 x 12mm round head screws (allen key style)
6 rubber washers to fit iunder the grille between it and the body and 6 x M5 lock nuts (cycolac nuts)
and an allen key and 6mm socket I think does the job.
The 12mm is the length of the thread, head depth is 3mm and I am certain these are original (match parts book anyway and markings look original).
Should be able to locate easily if they aren't there allready.
