chris
the initial figure on the longstone website for freight comes up at about that number BUT if you then click thru the system gives you a discount back, in my case, back to 150 pounds. I had no problem with the on line order - it was actioned and the tyres were on their way in about an hour. see attached
I looked at ordering in two lots but the extra freight is higher than the GST - freight seemed to be 150 pounds for the lot or for each lot of two versus in my case GST of $166
