Hi Guys,
Is it normal:
1. for the gauge illumination to be so poor you can't read the numbers on the gauges? The lighting is good enough to highlight the markers, but having a nice to see gauge at night is simply not possible at the moment. The rheostat controlling the brightness is working fine (0-5ohm range).
Thanks in advance,
Nick
I'll probably build on this thread as the question of 'Is this normal?' seems to come up quite a bit.
As can probably be seen with the number of posts etc I have done, I have become a P-car owner only very recently. Always admired/desired them, just took a while to take the plunge.
Anyway, the key question I need answered before diving off any trying to fix something is whether or not I should expect it to start with!
Is it normal:
Thanks in advance,
Nick
