You must become a member of the Australian Typ 901 Register in order to be post at this website.
Once you become a member an invitation to register at this website will be emailed to you.
Membership information can be found by clicking here.
Car was still only running at 99% had an annoying slight hesitation
Sent the distributor out for rebuilding...no better.
Decided to look further
Remembering that the car ran very very strongly we decided to follow the MFI Check measure and Adjust manual to the letter of the law and did a compression/leak down test
To my horrow 2 cylinders were 40% down which lead to the following
Full rebaild, throttle bodies done and MFI pump in progress
So Clyde, just how many 901s have you "rescued"? And what has happened to the green meanie RSR?
Paul M
More than my share Paul, the Viper Green ST spent some time on the showroom at Porsche but now has the engine out again and we have a list of all the things needed for completion....one day
Well 11 mths after going in for some minor cosmetic surgery and coming out with a triple by pass the yellow E is back home.
First drive today was good and looking forward to testing it somewhat at the Sth Gippsland run
It got a full dry ice clean up full engine, MFI pump and throttle body rebuild all to STD E specs
Kane has taken on the task of decoding the mysteries of the MFI pump, he bought a genuine Bosch machine and is studying furoiously
to get his head around it all. It will be great to have someone who knows what is what with these pumps right here in Australia.
Here are some finished pics, Kane did a great job.
looks excellent Clyde, Kane is going to be a very busy boy if he gets know as an MFI specialist, Mark Jung is months of waiting and Gus must be close to calling it a day.
Craig
12/1969 E based Vintage Racer
1972 2.4E Targa project
1973 911 2.4E for the road
Yes that is his aim for sure
He has watched a lot of You Tube videos and read the bible several times
He was learning on my pump, which turned out to be pretty good anyway and I am sure he will continue to expand his
knowledge base in search of the shills to check and then maybe rebuild where necessary too.
